Results 1 to 4 of 4
Thread: Delco Remy voltage regulator
    marinelubricants's Avatar
    Nov 2003
    57
    Steve Pierce and T.J. Hinkle: Thanks for your advice on my old 320 engine problems. I dropped the engine off at Penn Yan last Friday (the hours since new, etc are hard to determine because early logs are missing (engine is 1955 vintage/thus I did not get back to T.J. with answers to his questions) and if the narrow case and crank are OK will do a Superior overhaul with a 5 yr warranty or TBO which ever comes first taking oil samples twice a year. Will hear tomorrow whether the crank and case in OK! Anyway, sent generator off for overhaul and then found Delco Remy voltage regulator had been arching to a bolt located behind it on the fire wall (bolt with no nut and not holding anything) arching field terminal that smoked the regulating coil and burned the points. What are people using in 2005 for a regulator with the old generator still working. Thanks again to all who help this old goat and his NOT DO Bargain 1956 PA-18A Cub. Jerry McCammon
    T.J.'s Avatar
    Apr 2002
    Alaska
    3,211
    delete
    Jon B.'s Avatar
    Willmar, MN (KBDH)
    712
    I've heard, TJ, that a regulator can easily be repaired by installing your old PMA'd cover on a new automotive AC-Delco regulator. That seems like it would pass the "minor repair" smell test, wouldn't it? (wink, wink)
    *I* would never do that, though. Nope. Not me. Never.
    Jon B.
    17,382
    Which generator do you have? I probably have a spare regulator.
  1. Delco-Remy generator weight
    By bearsnack in forum Cafe Supercub
    Last Post: 03-12-2010, 07:30 AM
  2. Delco-Remy Generator spare parts
    By SEFYK in forum Products, Purchases, Reviews & Prices
    Last Post: 01-17-2010, 01:22 PM
