Results 1 to 13 of 13
Thread: manifold preasure guage
    Tim's Avatar
    Petersburgh, NY
    3,403
    I put a MP guage in my 2+2 (0-320) about a year ago (150 hours ago) and it's starting to get oil in it. I can just see the oil at the bottom of the guage. When I put the guage in someone told me this might happen, but I thought I would see what happens. Is there a filter I can put in the 1/8th line going to the guage, or maybe I should put a petcock in the line and drain it once a year.
    Speedo's Avatar
    Jul 2002
    AK
    1,669
    I've got oil in my MP gage, too. It seems to drain out on its own, and hasn't caused any obvious problems. I'm going to live with it unless a problem develops.
    Speedo
    N5126H's Avatar
    Anchorage, Alaska
    630
    My 14 has a MP gage that it came with 57 years ago. It is mounted towards the top of the panel and I have never had an oil problem. Maybe if you use less than 17 qts when you change oil it will not flow up to the gage.
    Tim's Avatar
    Petersburgh, NY
    3,403
    17 qts.! I only put 15 in there when I change the oil. It holds 8 and when I change the oil and filter I put in 7qts..
    Dec 2004
    Yarmouth, Nova Scotia
    480
    In my Rotorway helicopter, they advised to route the 1/8"line up as high as possible and then back down, to help keep fluid out of the guage. It's been working for me. I don't know if this would apply to a cub!
    Crash's Avatar
    Apr 2002
    Nikiski Alaska
    2,695
    What's a manifold pressure gauge? Crash
    Tim's Avatar
    Petersburgh, NY
    3,403
    That sounds like a good idea, I think I'll try it. Can't hurt
    17,382
    Pacers and Tri Pacers have a loop in the MP line above the cylinder with a hole in it. Maybe that is why Piper did that.
    Jerry Burr's Avatar
    Sedro Woolley, Washington.
    692
    Mp Oil
    This was a regular problem for me as I used the smallest line possible for the gage. I put a one inch piece of tube two sizes larger in the line where it went vertical. Never been a problem since.
    Crash. A MP and VSI are two instruments critical to accurate testing of flight parameters before and after any change to the airplane. A pair of 2" can either be velcroed in for testing or just istalled in the corner of the panel.
    Tim. You can disassemble the gage and wash it out. Just be very careful with the glass. They break (real) easy.
    Jerry.
    Tim's Avatar
    Petersburgh, NY
    3,403
    Thanks Jerry, I'am going up north next week after Sun&Fun. When I get up there I"ll take the guage out, clean it and put in a piece of larger tubeing
    N5126H's Avatar
    Anchorage, Alaska
    630
    Jerry:
    Don't make fun of my friend Crash. He cannot help it.
    Apr 2005
    Woodstock , Ontario
    223
    One of the simplest ways to stop oil is to make a small can and mount it with the cap to the bottom. Add two tubes on the top of the can for the inline connection from engine to gage. Oil will now collect in the can and not the gauge. Remove the cap to drain excess oil out as required. Some thing the size of 2 ounces is more than enough to do the job, and should be thick enough so it won't cave in from vacuum. Ron
    9,810
    Another easy fix is to simply install an automotive fuel line filter with replaceable element in the MP line. The filter will prevent any liquids from getting to the gauge. You aren't talking much liquid, either, so you can likely get away with changing the element once a year or so.
  1. 180 Lycoming manifold pressures??
    Last Post: 08-20-2004, 11:40 AM
  2. cub manifold pressure
    By jr.hammack in forum Modifications
    Last Post: 05-26-2003, 09:20 PM
