Results 1 to 7 of 7
Thread: Need dimension: Jury Strut fitting
    Bugs66's Avatar
    Feb 2004
    Spokane WA
    2,309
    I am building my D&E Super Cub wing and want to pre drill the spars for the jury strut attach fittings. The Piper drawings are a little mysterious. In looking at the front and rear spar drawings, I have come up with a number of 56.6 or 56.8in from the wing hinge hole to the jury strut holes.
    Can anyone verify or perhaps someone with a wing open could take a measurement from the wing hinge hole for me?
    Thanks for any help.
    Bugs
    cubunltd's Avatar
    Mar 2004
    Belle Vernon,PA
    1,138
    Bugs66,
    The Northland drawings show all the dimensions you'll need. It's a good investment for anyone building or repairing. If you need the measurement in a hurry, I can send you a copy of the spar drawings. I can try to fax them to you.
    John
    cubsunlimited@verizon.net
    Bugs66's Avatar
    Feb 2004
    Spokane WA
    2,309
    Thanks John,
    I do have the Northland drawings. That is where I came up with the 56in dimension. Just looking for a verification from an actual wing. The Piper drawings have several reference points, plus 4 different spar versions. The front and rear spars use a different points for reference, requiring some induction.
    T.J.'s Avatar
    Apr 2002
    Alaska
    3,211
    Bugs:
    Split the difference. Make it 56.7". 2" will not matter in the least for the position of the attach points.
    SuperCub MD's Avatar
    Jan 2002
    Collins, Wisconsin
    1,344
    56 13/16" on a original Piper rear spar. That is as accurate as I can get with a tape measure, so it would probably be 56.8".
    cubunltd's Avatar
    Mar 2004
    Belle Vernon,PA
    1,138
    TJ is right. .2" won't make any difference. Piper's tolerances were probably more than that. Fractional tolerances are usually pretty large.
    I came up with 56.82" on the prints. I measured an actual wing and it verifies that measurement.
    john
    Bugs66's Avatar
    Feb 2004
    Spokane WA
    2,309
    Thanks a bunch guys! Appreciate it.
  1. Prop bolt torque, jury strut bolts + jury strut spacer tube
    By BritishCubBloke in forum Super Cub Sick Bay
    Last Post: 11-15-2009, 04:20 PM
  2. Lift strut and Jury strut bracing
    By pa19guy in forum Modifications
    Last Post: 11-17-2003, 12:22 AM
