Results 1 to 4 of 4
Thread: O-320-B2C in a SuperCub?
    Any one out there ever have an O-320-B2C installed in there SuperCub? I realize that the type certificate says it should be an A2A or A2B
    From what i understand the difference in the B2C is in the Magnetos . We are
    getting Flak from the local authorities(South African) and they are saying that the engine must out unless we can produce an STC
    Any Sugestions
    Thanks ,Ben
    B2C is 160 hp with retard breaker mags. Cub Crafters has an STC for the 160 hp in the SC.
    Henry Ford
    As Steve said Cub Crafters STC should cover it. Here is a link to their Enging STC info page.
    http://www.cubcrafters.com/cc/products/160Engine.asp
    Good Luck.
    David.
    Thanks for the help , it is a lifesaver. Will get on to it right away
    Ben
