I'm in for an experimental project, and after all has been said and done, nothing seems to beat Mr. Piper's design. Add together bush flight, rough fields, rough environment, simple maintenance, load capacity, duct-tape fixin', low-slow maneuverability, stock and aftermarket parts availability, all possible mods already tried-and-tested, and a bunch of aficionados that can help or advise you on each and every detail of the construction, maintenance and operation of the beast, and there is only one name coming out of my Cray mainframe computer?
Experimental is the way to go for me because I love to build things, and always find something to modify on whatever I buy, barter, or find on the ground. Not to mention that building your own plane is the best way to know and understand it down to the last screw, and that you can spread the expense over as long or as short a period you may have to.
Although I've got lots of info on all the best Cub-like kits and parts, I'd like to have some on the Wag Aero.
Does anyone around here have experience with the Wag Aero 2+2? I'd like info about this plane/kit. The Wag site's page on the 2+2 is still in construction, and I don't even have their specs.
How well made is the kit, how does the aircraft handle, and any other comment and comparison to an equivalent Piper??
Any other input welcome!
