Steve Pierce wrote:
Sporty's sells a good product for the belly called Carbon X. Pour it in the water or spray some on the grimy stuff and it cuts it very well.
I would be careful with Carbon X. As with most "miracle" cleaners, there is a reason it works so well IT'S REALLY STRONG! You have to be SURE to wash off any residue from any aluminum or it will - over time - begin to corrode the aluminum.
Crash wrote:
Air Tech doesn't impress me at all. Every plane I've seen covered with it that I've thumped with my finger felt like a loose drum, floppy. The fabric just flops back and forth in any large areas. The finish is smooth with no fabric weave showing which means "thick coating", and that means "heavy". When I thump my ceconite with dope, it sounds like a bongo drum, tight!
Something that I have found with AirTech is that if someone has previous experience with dope on Ceconite you are used to primarily attaching the fabric to the structure in a "loose" state. (I think some reference the ability to lift the fabric an inch over the structure?) Ironing takes out all this bagginess, but the fabric isn't "drum tight"; the dope is what pulls it really tight.
Applying the fabric in this manner with AirTech would be a really bad idea. One would want to pull the fabric as snug as possible when initially attaching it. The only tightening will come from the iron as the "liquid" you will apply has no shrinking properties.
I don't know how tight is too tight (unless, of course, you reach the point of deforming things), but fabric that is loose or flops back and fourth in large area or balloons between the ribs in flight is definitely too loose.
Dope ("Ceconite"), Ployfiber, and AirTech are each methods of fabric covering, but each requires a different technique to apply. I had previous experience with dope, took a Sport Air workshop on Polyfiber, then covered my first "whole" airplane with AirTech. There were definitely some things I had to Unlearn to do the AirTech right. (In truth it was "too" easy).
As far as the issue of weight, I don't have a provable answer. It seems clear that less coats = lighter weight - but what if you sand off most of the solids of multiple coats of dope? I wonder if AirTech's claim of weight savings is based on the weight of the materials used or the weight of the finished product???
I can say that the process of applying AirTech is less labor intensive than either dope or Polyfiber due to the virtual elimination of sanding. You get a "show" finish right out of the spray gun whether you want it or not and the finish is virtually impervious to staining from outside sources.
While I freely admit that I don't land in "unimproved" areas
as some of you do regularly, judging from the durability and flexibility of the AirTech covering jobs I have had my hands in I seriously wonder if they wouldn't stand up to the brush and stone damage conditions you guys deal with better than "bongo drum tight" dope??
As with most of the discussions on this site, the only way to answer it is financially unfeasible - put 3 properly covered dope, Polyfiber and AirTech Super Cubs to work side by side for a season and then judge the results. Well, when I win the lottery....
John Scott
