180 hp PA-12
At this point in time, I feel you would be better off to go with a PA-18 Widebody Airframes Inc fuselage (if you need the room) and a Penn Yan 180 hp conversion. You can get a full 28" wide rear seat that has almost no taper to the back edge. The PA-12 rear seat is around 30" in the front but tapers to 26" at the rear edge. The Widebody PA-18 will get off quicker, have a 2,000 lb gross weight (Wip STC), three good fuel tank options, better designed cowling, three different exhaust options, better fuselage!! (Airframes Inc vs Dakota Airframe), better and easier resale, better slow flight and shorter landings, two fuel system options, better trim system, better door access (less knee bend for us old timers) and a much shoter time to build up. The PA-12 is a great plane but given the choice between the two projects (180 hp PA-12 vs 180 hp WB PA-18), I would choose the Widebody PA-18. Take care. Crash
