WindOnHisNose
BENEFACTOR
Lino Lakes MN (MY18)
Dennis Smith has established a column in STOL magazine for flying with pets, beginning in this quarter's issue.
I use a chest harness rather than neck collar for more safety for you and the dog. Remove any electronic collar so they are not accidentally activated by radio or transponder activity. Hearing protection if the plane is too noisy for you.
Just some of my musings on this very popular topic:
I have not flown with my dog yet, though I've been pondering the matter for a couple of years now. Why the procrastination? First, I'm worried about his hearing. My exhaust has no muffler and it's really loud in the cockpit without our noise-cancelling headsets. I bought a pair of Mutt Muffs for the dog and tried them on myself :lol:. Frankly, they don't do much to muffle the noise, as far as I can tell. The hard-shell design might look cool but a simple elastic cloth headband over some sound-deadening foam, perhaps fastened with Velcro and with a strap to his collar so he couldn't pull them off forward - I think that would be a much better design.
My dog is almost a "Gerberian Shepsky", a German Shepherd-Husky (though not Siberian) cross. He's about 60 or 70 pounds. He can ride in the baggage, on top of a bunch of camping/survival gear (in summer, on floats, much of that stuff can go in the float compartments, leaving more room in the baggage for the dog). The trick will be to manoeuver him around the tubing in the PA-12 baggage. He will be secured with a short neck line to that tubing.
On our first flight I hope that my wife (who is not much of a "dog person") will try to calm him down and make sure his hearing protection stays on.
If he does well then he will ride in the back seat area when I have no passenger. I'll take the seat cushions out to give him more space and I have a plywood "cargo floor" that sits in place of the bottom seat cushion and extends right to the back of the front seat, with a box built-in over the rear stick stub. I have a blanket for him to lay on and he would, in this position, be clipped to the rear seat cross-bar. He'd have lots of room.
He is fairly well-behaved but I want to have a "minder" for that first flight.
So, some pictures !
View attachment 32813 The back of my cub "before" removal
View attachment 32814 Once everything is removed
There is a battery to protect (fixed on the floor) and the lines connected to the rear header tank.
I will design protections.
View attachment 32815 She appears to be fine at the rear... at least in the hangar !
I will probably level her slightly higher
Maybe make a pillow for her with the aircraft cover ?
So, that is where I start...
Yep I fly dogs. Look at sled dogs in Cub. -20F at Skwentna flying dropped sled dogs from Su300 with Denny.Hi Denny
Thanks for your answer.
Do you have any pic ? What you describe is what I need to do.
The back of my cub is partially closed, so I will have to remove the existing installation, and find a way so that the battery (located behind) remains protected.
I will try to post a pic.
My boyfriend will seat behind, I have a control stick cover STC for the back seat that allows me to remove rear stick, but I will not remove it. My boyfriend is not a pilot but he can probably handle the airplane if needed so I prefer to keep the airplane flyable from behind.
Yes, the dog will have a short leash so that she cannot come to the front in case she panics.
She already flew a lot (she is ok but she is not fond of that), but she flew only once in the cub, she was on my boyfriend's knees. Was ok, but certainly not an option for a long trip
The resulting W&B will certainly not allow those short mountain strips I usually enjoy but flying all together will be great.
And you are right, we will have to travel with very little luggage
Alexandra
Barnie was that way. He could smell a carcus at 2 miles. Dug through snow at Shell in December and got a rotten one sticking out of ice. Yew!!!!Most Alaskan dog owners who take their dogs along are familiar with their dogs rolling in rotten fish carcasses or bear scat. Sometimes a belly pod would be the best place to put the dog! [emoji38]
