Results 1 to 5 of 5
Thread: Control Surface Travels
    Model: J5C (PA12 want-a-be). TC data sheet shows flight control travels in degrees up and down. I assume these are measured relative to the aircraft being level. Rigging instructions are shown in the service letters, however they do not address control surface travels. My service manual also does not cover travels.
    Could anyone help out, as to what the TC data specified control surface travels are measure relative to what??
    I believe the "0" degree reference is at the neutral position for that surface or neutral relative to the horiz. stab. in the case of the elevator.
    Mikey
    Greg Smith's Avatar
    Oct 2003
    Safe Skies Aviation, KMWO, Middletown, OH
    526
    Easy to measure if you can get ahold of a prop protractor or a smart level. Pitch attitude doesn't matter... Three point on level ground is fine. Zero it with the control surface in trail, then measure the deflection up or down.
    Here's a link to AC 65-15A at faa.gov. It is covered on page 72.
    http://www.airweb.faa.gov/Regulatory...hapter%202.pdf
    Measuring angles from the nuetral point, works great for ailerons. However, with the cub elevators, where is nuetral. If it is faired with the stab? Then, what position do you put the stab into to obain zero? Where is the stab's zero reference point?
    All other aircraft I have worked on, the manufacturers manuals give specific instructions. My cub manuals give no light on the subject, so I thought some Cub Expert could enlighten me.
    Thanks for everyones help.
    Hi Roger
    Level flight position or parallel to the horizontal reference line. Various ways to do this.
    Mark
    http://thrustline.com/
  1. Control Surface Deflections
    By BES in forum Modifications
    Last Post: 04-22-2009, 07:52 AM
  2. Control Surface bushings
    By cubscout in forum Products, Purchases, Reviews & Prices
    Last Post: 05-08-2007, 07:14 AM
