Oh that looks nice too (Kestrel post above). I had the first version Dynon D10 in the Moose I built back in the day (I think 2006) I still had steam gauges also.
My Javron Cub will be VFR HDX Skyview (but all it would take is to add any IFR navigator and it's IFR - no plans at this point but I will save space for it behind and in the panel). When I got back into GA/experimental 9 months ago the supply chain thing was a shocker. The Skyview HDX was 5 month backorder. Some said wait as it will get superseded by the time kit is done. But after reading everything and watching every video I could find there is little they could do to make me wish I had not purchased - ha, the dang thing is better than anytihng in the Boeing or Airbus that I just stopped flying. HDX just arrived, everything I need is on the shelf here already waiting (comm, transponder, GPS, ADSB, Engine EMS, etc. etc.) only thing I did not purchase ahead are the harnesses - I plan to get all the avionics locations figured then get the correct length instead of guessing. I can actually start doing that soon. Now if I only had wings and an engine.. LOL (all 'on order' since last August). Just the packaging of the Dynon gave me a warm fuzzy, well done. I am sure Garmin is same and looks very nice but I came up less expensive everytime I compared the two.
Sorry wordy for I will have no other analog/archaic type backup either. VFR of course. I do have the backup battery for the Skyview though.
I wish (getting off track, well maybe not this was about panels in experimental) there was an easy way to put a screen on the back of the front seat for when my wife is in the front and I am in the back and have all the Dynon repeated there. It is doable with an iPad and other various software. But my one silly requirement is to have actual airspeed in the back not just GPS speed (I know I know you don't need it yada yada) but it's nice if communicating with someone in the front seat to use the same numbers) Something like the '
Bom' sends actual AS, but then you could just go with that alone front and back. Sooo many option it is hard to sort it all out. Of course all is crazy $$ - on that note, in the end I'll probably just look over her shoulder like always.
EDIT: You guys type faster so Kestral post is three above this.. my bad for not quoting.
