dirtysidedown
Report
Newbie here but not new to Cubs.
I have been flying Cubs all year round for going on 34 years in Alaska.
Floats, wheels, skis. big tires, Borer props (41-44), VGs, extended wings, extended flaps, droop tips, Hendricks tips and Hendricks tail feathers. 135, 150 160 180HP. Extended metal leading edge. This oil, that oil. Yadda. Flown lots of Cubs. Owned four over the years. Heard it all. I thought----
Never even THOUGHT about the thrust line as a possiblity for performance enhancement. Heard of some nutjobs that put washers under the bottom mount lugs but considered them fringy freaks like the guys before VGs that beat the pucky out of their leading edge with a ball-peen for better performance.
Pretty much heard (or spun) just about every Cub yarn concerning performance, technique, etc there is.
Boils down to the mods I wouldn't give up. Fight me for em. Not going to give up my Borer prop, 30 inch tires, VGs, booster brakes, or belly tank.
Kind of thought I tried it all. None of the other mods made much difference but those gotta stay.
Now got to add one more item to the list. The Thrustline mod.
Wow. Definitely a keeper.
1958 PA18A Stock except 160HP, belly tank, VGs (orig microaerodynamics-- wing only) 82/44 McCaulley, Airstreaks.
A really good performing Cub before the mod.
Now:
Way nicer handling at low airspeed. More controllable nearing stall with smaller bursts of power. Nicer sight picture at slower approach
Shorter takeoff role
Nicer climb.
5 MPH faster cruise @2450---- Really!
2 1/2" more prop clearance
Haven't flown it heavy yet but have no reason to believe it won't be better there too.
Maybe a little more abrupt stall at last 2 notches of flaps (yep, A models have an extra notch) but clean it just sort of settles with power on or off. No break.
Most of the angle change occurred WITHIN the cowl.
Very slight, cowling change. I seriously might have missed it had someone sneaked into my hangar and stuck the mod on while I was away.
Best part is dealing with Mark Englerth. Super nice family guy. Very smart, solid knowledge foundation. Extraordinarily researched and implimented STC. Parts and paperwork first rate. Easy install (heh,heh--I just handed him tools)
If you like prospecting with your Cub this should be required equipment.
Now:
Nicer climb.
