Results 1 to 10 of 10
Thread: Experimental Cub: Floorboards - alum or wood?
    Bugs66's Avatar
    Feb 2004
    Spokane WA
    2,299
    The Bearhawk Patrol is using aluminum floorboards. Apparently they are holding up well. Which floorboards would you go with, plywood or aluminum if you had the choice? The aluminum saves a bit of weight.
    Related to aluminum floors and sides... What is everyone using for "sound deadening spray" on aluminum panels. Piper drawings make reference to sound deadening spray.
    Bugs
    RMREBOB's Avatar
    Oct 2002
    Arlington, Texas
    264
    I have seen carbon fiber honeycomb that is unbelievably strong and unbelievably light. I spoke to the Graphite Store (http://www.GRAPHITESTORE.com) and they said that they have it available in a variety of thickness. Also we use carbon fiber panels on the interior of our race cars and I think it would work great for interior panels, headliner, etc.
    D. Davis's Avatar
    Peters Creek, Alaska
    95
    floorboards
    Hi,
    I rebuilt my cub with aluminum floorboards. When I looked at the old
    ones with warbled out holes I thought I was a good solution. Lately I am
    thinking of replacing the floor with composite. I will try the baggage
    floor first and weigh the difference.
    Dave.
    klm_ak's Avatar
    Aug 2002
    Alaska
    258
    I'm not convinced that aluminum floorboards are a panacea. Mine (0.063") are about 5# heavier than the wood they replaced and they seem to transfer the aircraft vibration to my feet much worse than the wood. On the plus side, they are much prettier than the old plywood, and I don't have the carpet on top (~2#).
    A friend's PA-12 has the diamond plate style aluminum floorboards, they are much heavier but I don't notice the vibration at all.
    fatcub's Avatar
    Dec 2002
    Enumclaw, WA.
    229
    Honeycomb is the way to go, but it is alot more work. You have to install inserts at all the screw and bolt holes. Also the edge should be sealed at the door if not the entire way around the panels edge. And the cost is substantial as opposed to the wood floor.
    If the choice comes to aluminum VS wood I would go wood for the ease, cost and the sound suppression. If you have ever been in a cub with a aluminum interior you know that sound.
    Scott.
    Clearwater,Fl
    2,514
    wood.
    hottshot's Avatar
    Jun 2002
    Joseph ,Or
    1,067
    Cargon Fiber ---- waaayyyyy lliiiight!!!
    StewartB
    Guest
    My plane is certified, and I used aluminum. If experimental, I'd have used composites. Call the boys at Certified Aircraft Composites www.cacalaska.com who have some cool stuff that's not quite legal (yet) for the rest of us. If you go with wood, treat it with Nelsonite before you varnish it. It'll last forever. Nelsonite is a clear penetrating sealer. Even if you scratch the varnish, the wood will last forever. Ever wonder how pool cues stay so pretty for so long? Nelsonite.
    SB
    Bugs66's Avatar
    Feb 2004
    Spokane WA
    2,299
    So when you guys say composites, are you referring to glass/foam sandwich? Anyone else have tips on fabrication?
    Bugs
    Crash's Avatar
    Apr 2002
    Nikiski Alaska
    2,695
    Floor Boards
    Northland has the nicest Birch 10 ply floor boards going if you decide to go with wood. CAS plastics has some great honey comb products that some guys got F.A.'d before the change in the FAA. I might try this on my next project. You do need to sleeve all the bolt holes though as mentioned before. Crash
  1. Wood floorboards
    By bearsnack in forum Tips and Tricks
    Last Post: 12-08-2004, 04:16 PM
  2. Wood floorboards in Wipline float lockers
    By SJ in forum Tips and Tricks
    Last Post: 07-17-2004, 08:44 AM
