Results 1 to 10 of 10
Thread: Trim cable rubbing on extended bagage compartment
    Jul 2003
    Clovis, CA
    232
    I am putting one of Atlees bagage compartments in my 1951 SC 135 (the one that hangs on the cross bar) and the right trim cable that comes off the 4" trim wheel that makes a straight line to the 1" pulley on the diagonal tube adjacent to the opening of the bagage compartment hits the box hard about 1 1/2" deflection of the cable. I have the wrap around trim pulley with the spring loaded pulley on the right side in back. Mr Dodge has been gone and I cant seem to get an anwser on this problem. Can any one help? Palhal
    17,924
    I seem to remember this problem. Seems like there was a piece of teflon fastened to the extended baggage where it rubbed.
    cubdrvr's Avatar
    Jan 2002
    1,108
    You're right Steve.........there was one, I think, rivited on the back corner.
    gdafoe's Avatar
    843
    That is correct BUT the cable just hits the teflon barely. His seems to be out of correct alinement or something.
    Gerald
    labdad32
    Guest
    Dodge baggage
    I checked the area on the baggage I just removed and it shows two small grooves at the very back, right where the plastic strap is positioned.
    Jul 2003
    Clovis, CA
    232
    Re: Dodge baggage
    Quote Originally Posted by labdad32
    Did it put about a 1 1/2" deflection in the right trim cable when the box was installed?
    labdad32
    Guest
    Dodge Baggage
    Good question, I don't remember. Sorry. When I framed the new extended baggage I welded in another set of 1" pulley brackets and trim indicator bracket rearward to keep the cables away from the new area.
    May 2003
    34
    Just getting done recovering one with dodges extended. Whoever installed it had it all cockeyed. After centering and setting fairly level the trim cables rubbed right on the teflon. I also added a piece of rubber hose on the rear flange of the compartment. This one was installed over 500 hours ago and was rubbig on the compartment not the teflon and hadnt caused any damage to speak of, the cable hadnt frayed yet.
    Rick
    S2D's Avatar
    Montana
    3,970
    Palhal
    Looking at two cubs here, it appears that is normal. In the area of that corner, the lower cable sticks out toward the center of the airplane about 1 1/2 inches on an unaltered cub. on the Extended baggage cub, this cable is pushed over even with the top cable. Top cable lightly touches corner and bottom cable definitely touches corner.
    Jul 2003
    Clovis, CA
    232
    Quote Originally Posted by S2D
    Palhal
    Thanks everyone. I will just close my eyes and let the cable rub on the teflon strip.
  1. extended baggage compartment for a pa-12
    By buckeye in forum Tales of the PA18
    Last Post: 04-04-2009, 10:56 AM
  2. Replies: 10
    Last Post: 12-07-2005, 02:55 PM
