Results 1 to 4 of 4
Thread: Aux Tank Feeding
    SuperCub MD's Avatar
    Jan 2002
    Collins, Wisconsin
    1,344
    Aux Tank Feeding
    On wing mounted aux tanks that just do not want to feed in flight, has anyone come up with any fixes? The trouble usually is a normal vented cap being in a low pressure area. I usually recommend a pito tube type pressure vented cap, and make sure all the lines and outlet screen is clear, and that fixes it. Just wondering if someone has come up with anything else.
    behindpropellers's Avatar
    NE Ohio
    6,650
    Gas cap vents....
    My friends j-3 has an aux tank in the wing. They have cap with a tube welded onto it that points forward into the airstream. Just do not put the cap on backwards!
    Nov 2002
    Charlotte, NC
    1,859
    I had a J3 with a small aux wing tank (6 gal, I think) and it was really hard to get it to feed unless the main tank was about 2/3 empty. It just got to be a habit not to even to try to transfer unless the main tank was way down. I then usually had no problem getting the fuel to transfer. (Of course if you were sitting on the ground and tried it with the main tank nearly full it would IMMEDIATELY overflow!!!) The cap had a welded on vent tube that we always pointed to the front (opening into the airflow).
    Hope this gives you some ideas!
    John Scott
    Jan 2002
    Collins, Wisconsin
    1,344
    On Wag Aero J3 wing tanks, the STC specifies ram air vented caps. But their catalog says to buy plain vented caps with the tanks. The catalog is wrong. The ram air caps are needed to push fuel down into the main tank.
    If you have, or know someone with these tanks, make sure they have the proper ram air vented caps installed.
  1. Fuel tank leak right tank
    By RAC cubs in forum Tips and Tricks
    Last Post: 11-11-2010, 02:18 PM
  2. Contact, Air Force Jet and Army Tank, the tank won
    By AlaskaAV in forum Alaska Av Memories
    Last Post: 07-26-2004, 06:17 PM
