Here is a little training aide for us neophyte cub pilots. If you have access to an airport with crossed runways and low traffic make a t.o from one, bend it around and land on the crosswind. T.O. again and then bend it around and land on the runway you started from. Continue until you have had enough takeoffs and landings for the day. You get about double of the landings in an hour, which for some of us, is needed. Given the right conditions you get to practice t.o.s and landings with the wind from every direction.
Lug
